Switch Hardware and Software
niSwitch_Init error
When calling the function niSwitch_Init from Visual C++, I recieve an error of BFFC0011 for PXI-2567.  In MAX the self-test passes and I'm using the correct alias setup in MAX in my function call.
My Computer information:
Vista
NI-Switch 3.8
MAX 4.5.1
NI-DAQmx 8.8
NI-VISA 4.4.1
Message 1 of 20
(9,052 Views)
Hey Guy,
Error BFFC0011 is a generic failed to query device error.  In MAX, are you able to open the soft front panel without error?  We can do this by right clicking on the 2567 and selecting "Test Panels".  Do you have any other NI Switch Modules in the system?  If so, are they working?  Do you have any other PXI chassis we can test the board in?
Also, can we get a screen shot of your device in MAX?
Message Edited by Knights Who Say NI on 03-01-2010 05:30 PM
-John Sullivan
Problem Solver
Message 2 of 20
(9,030 Views)
I also have a PXI-2568 which is encountering the same issue.  I am able to use the test panel from MAX correctly.  I am currently updating the NI-SWITCH driver to 4.0.1 to see if this fixes the issue.
Message Edited by Guy04 on 03-01-2010 05:40 PM
Message 3 of 20
(9,025 Views)
Hey Guy,
Depending on the order we installed the NI-Switch driver, it's possible we didn't include the support files needed for C++.  Installing the 4.0.1 driver would resolve this issue; we could also repair the version of the driver you have installed now.  I'd go with 4.0.1 if you meet the system requirements.
-John Sullivan
Problem Solver
Message 4 of 20
(9,021 Views)
How could I resolve this with my current driver.  I think my system should be compatible with 4.0.1 but, if not then how or which order should have the drivers been installed?
Also when do the support files for C++ get installed and how can I verify it?
Thanks.
Message Edited by Guy04 on 03-01-2010 05:51 PM
Message 5 of 20
(9,017 Views)
With your current driver, open Add/Remove Programs, double click on National Instruments Software, select NI-Switch and click repair.  This will reopen the installer window.  Make sure that the drivers you'd like installed are selected.  The currently installed drivers will already be selected.
FYI: We should always install the programming environment, any toolkits or modules, and then the drivers, followed by the hardware.
-John Sullivan
Problem Solver
Message 6 of 20
(9,012 Views)
