Switch Hardware and Software
multiplexer 1127 one wire configuration
I use the multiplexer 1127 with the terminal block 1331. I want to connect 64x1 one wire configuration. But, low channel number (0-32) is working, but high channel (33-64) does not work (there is trivial signal). I refered to the manual. I coundn't find something new. Please let me know if you have any suggestion or help. Thanks!
Message 1 of 10
(9,835 Views)
Hi naba,
Can you see your signals when you use the Switch Soft Front Panel?
All Programs >> National Instruments >> NI-SWITCH >> NI-SWITCH Soft Front Panel
If you cannot see your signals, select File >> Options, and select to Enable changing relay positions.  Then, on the Relay tab, find the HLSELECT relay.  When you toggle this relay, do you hear clicking?
Let me know.  We'll figure this out.
Chad Erickson
Switch Product Support Engineer
NI - USA
Message 2 of 10
(9,833 Views)
Thank you for your reply.
Yes. When I used the NI-Switch software, I can hear the clicking sound.
But, I can also hear the clicking sound when I used my VI. The measured signal is a trivial.
Message 3 of 10
(9,828 Views)
Hi naba,
Can you see a signal on channel 33 when using the Soft Front Panel?
Thanks!
Chad Erickson
NI - USA
Message 4 of 10
(9,826 Views)
I can see a signal from ch 0-31. But I cannot see a signal from ch 32-63.
Message 5 of 10
(9,823 Views)
Hi naba,
The signal will propagate from the channel through the CHx and HLSELECT relays to OUT0+.  We know that the CHx relays are working because you are able to see the signals on channels 0 through 31.  The HLSELECT relay is suspect.  Please verify again that the HLSELECT relay is working: toggle only this relay in the SWITCH Soft Front Panel and listen for clicking.
Hope this helps!
Chad Erickson
NI - USA
Message Edited by Chad PSE on 09-04-2008 12:51 PM
Message 6 of 10
(9,818 Views)
I changed VI from relay.vi to switch.vi. Then, I can get a signal through high channel (ch32-ch63).
I wonder if relay.vi cannot use for high channel?
Message 7 of 10
(9,804 Views)
Hi naba,
relay.vi can be used for high channels, you just have to toggle HLSELECT.  I've attached a picture of the SCXI-1127's hardware diagram.  This can be found in the NI Switches Help.  All Programs >> National Instruments >> NI-SWITCH >> Documentation >> NI Switches Help.
As you can see, in a 1-wire topology, ch0 is connected at the same time as ch32, and toggling the HLSELECT relay allows ch32 to connect to COM0 instead of ch0.
To use relay.vi, simply close ch0 and HLSELECT.
Let me know if you have further questions!
Chad Erickson
NI - USA
Message 8 of 10
(9,802 Views)
Can you teach me or show one example how to close ch0 and HLSELECT ?
Message 9 of 10
(9,790 Views)
Hello naba,
From the image that Chad sent you, you can see that to connect CH0 or CH32 to the COM0 you will need to close relays CH0 and HLSELECT.  To do this you will need to run the Relay Control VI twice.  This picture should give you an idea of how to do this in LabVIEW.  Also, check out the switch examples.  You can find them in your Start menu in Programs -> National Instruments -> NI-Switch -> Examples.  From there, choose your API.  This will show all of the examples for LabVIEW for programming a switch.  Check out the example niSwitch Controlling an Individual Relay.vi for the code on what I have shown you.
Message Edited by BrowningG on 09-08-2008 05:19 PM
Browning G
FlexRIO R&D
Message 10 of 10
(9,764 Views)
