08-11-2010 04:32 PM
It the 66 pin right angle connector that plugs into J1 (SAMTEC FLE-137-01-G-DV-P-TR) on the Module Interface Board (192834 on the TB-2642). It's 2 row 39 position with only 33 position filled so it must be a semi custom part?
Darrow
Solved! Go to Solution.
08-13-2010 01:05 PM
Hi Darrow,
It is a FSH 39 pin shrouded terminal strip, with only 33 pins populated. The base part number is FSH-39-D-ES-35, and it is a semi custom part. Are you trying to make your own custom connections?
08-13-2010 08:19 PM
Yes, I'm replacing the column board with something like this...
08-16-2010 06:44 PM
Hey Darrow,
Are you familiar with the PXI-2531, which uses VHDCI connectors as breakouts instead of ribbon cables?
This module is similar to the PXI-2532, but is only rated to 60VDC and doesn't support as many topologies as the 2532. See the specification sheet for more info.
This would prevent the design of such a cable.
If you do go through with the custom cable, make sure you provide sufficient strain relief.
John Sullivan
Switch Product Support Engineer
