Do you know of a good way to cancel the path resistance?
It sounds like you may have solved my problem here. I'll have to try this out and see. Basically what you're saying is I have to configure all the channels (using MAX) to 1wire. Then I can freely use the independent mode to make 1,2, or 4 wire measurements with full relay control??
If that's the case then you may ignore the following. If that isn't the case, let me describe what I'm trying to do.
I'm glad you pointed out that last piece of information. The reason I want to use this device in independent mode is because I plan to account for the 400 to 800 ohm path resistance of the 1128 (and not have to buy a 4070). I think I can do it, but I'd have to be able to use any channel (ch0 for example) as both a 1 wire and a 2 wire terminal (no need to do it simulataneously, I just have to be able to go back and forth). If I phyically connect ch0+ directly to 1wire_lo_ref and connect ch0- to my 1K resistor and then connect the other side of the 1k to 1wire_lo_ref, I am hoping to be able to determine the path resistance of the entire switch. In order to do this I'd have to take three 2-wire measurements. One from ch0+ to the ref, one from ch0- to the ref, and then I'd have to set up ch0 as a 2 wire terminal and measure the entire path resistance. By using the first two measurments I can calculate the parallel resistance of the ch0+ and ch0- and then I can do some math to cancel out the path resistance. Long story to come to my ultimate question, but I guess what I'm asking is:
Can I use the 1128 in independent mode and configure ch0 as a 1 wire channel (i.e. ch0+ and ch0- with 1wire_lo_ref as a common) and then configure it as a 2wire channel(simply ch0)?
Here's an ascii of the circuit:
|=== 1wire_lo_ref
Rpath(1wire)
_____|___________
1K |
Rpath ch0- Rpath ch0+
ch0- ch0+
| |=============com0+
|=============================com0-
Thanks for the help, I hope configuring all channels to 1wire will solve my problem.
