Switch Hardware and Software
Switch in Teststand
Not sure if this is a Switch Exec or Teststand question.
In Teststand I can "Insert a Step>IVI-C> SWITCH"  If I select "Edit Switch" a drop down appears. If the "ACTION" is to "0-Connect" and the "Route(s) to Disconnect" is ALSO populated does it disconnect that route in additon to connecting the one in the "Route(s) to connect" field???
I've included a screen cap.  Even though the action is to connect does it disconnect too because that field is populated??  Using type c relays...not a mux if that helps.
"Go ahead, make my day"
Clint
(6,332 Views)
Hello Clint,
Even though the field is populated, the route will not be disconnected until you call a Disconnect or the Connection Lifetime has expired.  Sorry for the confusion, I will file a Product Suggestion to clear the Disconnect field if the action is set to Connect.  I invite you to do the same at the Product Suggestion Center.
Rod T.
(6,313 Views)
Not at all Rod.  I didn't think that BOTH statements were executed.  It was questioned by our QA person at a Review.  Now I have it in writting.
Thanks.
(6,304 Views)
