I am using NISE 3.6 and have developed a virtual switch. I have used NIMAX 15.3 to access the NISE and have ran simulation and verification and all seems to be well.
However, when I use the NISE API in LWCVI, both the NISE open session and close session calls throw non-debuggable exception errors. In the case of open session if I turn off first chance exception errors I can run to the close session call where a General Protection fault is thrown.
As both calls appear to work when validating the switch (as monitored in NI IO Trace) I assume the switch drivers are ok.
Has anyone else seen this issue?
Many Thanks,
Steve
