10-16-2006 03:35 PM
10-17-2006 10:59 PM
10-18-2006 09:27 PM
Thank you for the response, I think I got confused between switch executive 2.0.1 and 1.02. When I right click on the devices and interfaces and try to create a NI switchexecutive object it worked fine.
However, I still am facing a problem:
I am trying to create a new veirtual switch executive device (RFDrawer), it is not letting me use this particular name, I get a message "Virtual device name is not unique orcontains invalid characters" , but a virtual device with that name is not visible. I am thinking it might have it in memory some where and it is not letting me use it again. But I can create a virtual device RFDrawer1 and do validation etc..
Please let me know what is happening?
Regards
Papaiah Kummari
10-19-2006 03:46 PM
10-19-2006 04:57 PM
Hi Travis,
It worked, Thanks a lot.
It saved lot of time and effort for me, I was thinking of rebuiding the PC because this problem and below one.
Now that MAX works fine, I have another problem. When I exit from labview, it is not closing properly. Labview is active on task bar, I have right click , select Close then shutdown the application.
Is there any way I can get arroung this?
Papaiah Kummari
10-20-2006 02:48 PM
Hi Papaiah,
What happens when you close LabVIEW "Getting Started" window by selecting File->Exit ? Are you able to relaunch LabVIEW successfully ?
Tunde
10-20-2006 04:32 PM
10-23-2006 09:52 AM
Papaiah:
What version of LabVIEW and NI-MAX are you using? Are you running any vi before you try to close LabVIEW? Does running and closing NI-MAX show the same slowness?
Brian
