I'm using four SCXI-1127 modules in 1 wire mode. Lately, I've been experiencing problems with one of the 4 modules. When i try to read resistance of 4 individual resistors by connecting them to any of the 4 channels of modules installed in slots 2,3,and 4 of SCXI 1000 chassis, it gives me correct results. But with module in slot 1 i get two 'NaN' values either on 0 & 1 channels or 32 & 33 channels. I tried swapping modules, added and deleted them through MAX, and rebooted the PC several times. All of the modules are working correctly, when inserted in slots 2, 3, and 4 of SCXI 1000. I don�t understand what�s causing the module in slot 1 not to work. I tried debugging it through soft panel too, but the problem still persists. If anybody has
any suggestions please let me know.
Thank You
