I have a SPDT GP relay and I wanted to know how the routes should be created. For example, in NISE when you create a route you have two endpoints. Endpoint1= Comx but what should Endpoint2=?. Should it be:
Endpoint2=ncx or
Endpoint2=nox
Lets say the route name is called "MyRoute". If I chose my Endpoint2 to be "nox" then when I go into Teststand and use the "Switching tab" under Properties and say Connect "MyRoute" then the connection should be between "Comx->nox". Now when I say Disconnect "MyRoute" will this cause the connection to be "Comx->ncx"?
Thanks for your help in advance.
