Switch Hardware and Software
Pinout for PXI-2535
I need to build a custom board for the PXI-2535 to hook up signals instead of using the terminal blocks. I cannot find the correct manual though. Can someone please find the pinout descriptions of the 68 pin connectors for the PXI-2535 switch.
Walter
(6,739 Views)
Accepted by wgordy
Hi Walter,
I believe the pinout you want can be found in the NI Switches Help.  This manual is copied over to your machine if/when you install the NI-SWITCH driver.  It can also be downloaded from the following page: http://digital.ni.com/manuals.nsf/websearch/B133DDD29F0DFCC28625746E00564E56
Let me know if you have further questions!
Chad Erickson
Switches Product Support Engineer
NI - USA
(6,736 Views)
