08-03-2009 12:13 PM
I need to build a custom board for the PXI-2535 to hook up signals instead of using the terminal blocks. I cannot find the correct manual though. Can someone please find the pinout descriptions of the 68 pin connectors for the PXI-2535 switch.
Walter
08-03-2009
01:16 PM
- last edited on
03-20-2026
05:05 PM
by
Content Cleaner
Hi Walter,
I believe the pinout you want can be found in the NI Switches Help. This manual is copied over to your machine if/when you install the NI-SWITCH driver. It can also be downloaded from the following page: https://www.ni.com/docs/en-US/bundle/ni-switch/page/user-manual-welcome.html
Let me know if you have further questions!
Chad Erickson
Switches Product Support Engineer
NI - USA
