08-29-2006 01:55 AM
08-29-2006 08:22 AM
The best thing to do would be to swap the "protected" version for the "unprotected" version so that the resistance is not there. The protection resistors help to prevent inrush currents from capacitive loads which can easily damage/weld reed relays. If they have a resistive load, particularly at lower voltages, the protection isn't needed.
If swapping the terminal blocks is not feasible, you could replace the 100 ohm protection resistor with a 0 ohm short although we don't document how to do this, which resistor goes to which terminal, etc.
