Switch Hardware and Software
PXI-2522 missing Windows driver
I've got a PXI-2522 card installed in my PXI chassis and have installed NI-SWITCH 19.5 but Windows Device Manager says there is no driver available/installed. The readme file states that this card is supported. How do I resolve this issue?
Message 1 of 8
(7,840 Views)
Specifically which Windows OS are you using (and bitness).  If using Windows 10, which update are you using?
Is secure boot enabled?
I just installed NI-SWITCH 19.5 on Windows 10 x64 update 1903.  It installed and my PXI-2522 seems to work.
Message 2 of 8
(7,819 Views)
OS: Windows 10 Enterprise LTSC build 17763.
Secure boot is not enabled.
Message 3 of 8
(7,799 Views)
PS: What is the path to the driver file for your card? Maybe I can browse to it in Device Manager.
Message 4 of 8
(7,792 Views)
Message 5 of 8
(7,764 Views)
That DLL does not exist on my system even though I've installed the NI-SWITCH package. The title for that package says NI 2524/5/6, 273x, and 274x Switches. So it does not list the 2522, but the readme file shows it as supported hardware. Not sure what the issue is?
Message 6 of 8
(7,753 Views)
Accepted by topic author -DC-
You need to make sure to include support for the NI-DAQmx based switches:
The PXI-2522 is an NI-DAQmx-Based Switch.
Message 7 of 8
(7,751 Views)
Thanks, that was it. But I can't find anything in the readme or elsewhere that indicates it's DAQmx.
Message 8 of 8
(7,737 Views)
