I had not loaded the "NI-DAQ 7" software that came with the 2566 switch card. I assumed that since MAX showed that I had version 7.2 of DAQmx that I was already up to date.
I received a new PXI-2532 switch, and when I got a "driver not found" error in Switch Executive when I tried to add the 2532 to a new virtual device, I had second thoughts on running the setup/install from the new discs.
After running the software install, I was able to add the 2566 switches to a virtual device in Switch Executive. However, the 2532 failed.
Error xBFFA4B4A occurred.
DAQmx Error -200181 occurred:
Channel name specified is not valid for the switch device.
Device: PXI1Slot10
Channel Name: r4
