08-26-2021 03:58 AM
we have couple NI 9482 relay modules next to each other in a cdaq chassis and we'd like to design a simple pcb which we could snap on these series of modules. Does anyone know what is the P/N for the matching connector we can use on our PCB?
thx
09-03-2021 07:08 AM
Hello 1984,
It seems you are doing something really interesting.
As I understood you are searching part numbers for the connectors of NI-9482,
There are two types of connectors.
P/N 154928A-01 P/N 782715-01
I hope this will help you.
Greetings
09-03-2021 07:20 AM
Thanks man but I'm actually looking for a PCB mountable counter part and not a screw terminal version. We'd like to design a PCB we can snap on a series of relay modules instead of using wires from the screw terminal to the PCB.
09-03-2021 09:50 AM
Actually, there is an alternative, not a bad way to do that.
You can use board to board connectors
BG030 - Board to Board Connector Header 2.54mm pitch Straight (gct.co)
This is a connector type that can be used with NI-9927 terminals that are used in NI-9482.
09-09-2021 11:35 AM
I would not recommend plugging a board with direct connectors interfacing with multiple c-series cards at the same time, the issue is that the c-series card have a degree of play in both x and y axes and tolerances.
But if your intention is to have a board that connects to only one c-series module at a time, then fine because even if the module moves, the external board can also move with it.
09-13-2021 10:43 AM
Thx for your response. We've done thing like this, eg: we designed PCB-s for SCXI modules which had quite a bit of a play as well, so I'm not conerned about it.
