Switch Hardware and Software
IVI issue fo PXI 2532 based on VB.NET
I using PXI2532 based on VB.net programing to control the switch box.  I had posted another question ashttp://forums.ni.com/ni/board/message?board.id=320&thread.id=1362 before. That isuee had solved well.
But when I transfer my program code to another PC, I met another issue. I found a error as:
Public Shared Function ThrowError(ByVal handle As System.IntPtr, ByVal code As Integer) As Integer
            Dim status As Integer
            Dim size As Integer = PInvoke.GetError(handle, status, 0, Nothing)
            Dim msg As System.Text.StringBuilder = New System.Text.StringBuilder
            If (size >= 0) Then
                msg.Capacity = size
                PInvoke.GetError(handle, status, size, msg)
            End If
            Throw New System.Runtime.InteropServices.ExternalException(msg.ToString, code)
        End Function
    End Class
End Class
There is a external exception in blue part. It says:
"Invalid resource name.    If the resource descriptor is an IVI name, it must match the entry in the IVI Configuration Store in a case sensitive manner. "
I try to run a NI exampl in VB.net http://zone.ni.com/devzone/cda/epd/p/id/4577.
There is a error in same code. It says
"Insufficient location information or the device or resource is not present in the system.    Common errors when initializing a session:  - Mismatch between the device and topology.  - Resource descriptor is a device that is not a switch.  - Chassis not powered on."
I check this page for help:
http://zone.ni.com/devzone/cda/tut/p/id/4562.
But  I can't used none of two method to deal with this, for
I can't add "niSwitch_32.dll" as a  reference cause I used VB.net.
I can't find measurement studio , instrument driver cause I'm unable to use measurement studio.
Does anybody have idea? PLZ help
(7,725 Views)
PS:
the code I had meantioned is a part of niSwitch.vb.
(7,723 Views)
Hi C.,
Verify the resource descriptor in the program is identical to the resource descriptor in MAX.
Program Resource Descriptor:
MAX Resource Descriptor:
Hope this helps!
Chad Erickson
Switch Product Support Engineer
NI - USA
Message Edited by Chad PSE on 10-15-2008 08:50 AM
(7,709 Views)
What does the Measurement and Automation explorer say your switch device name is? Does it match what you're passing to the initialize function?
(edit to add: what Chad says above)
Message Edited by Srđan Zirojević on 10-15-2008 08:56 AM
(7,705 Views)
