03-26-2007 01:50 PM
03-27-2007 02:45 PM
Hi Rick,
The SCXI-1169 is a DAQmx-only device. You can control the SCXI-1169 with the PXI-6070E DAQ board, but you must configure a chassis under NI-DAQmx Devices. Right-click on DAQmx Devices, Create New NI-DAQmx Device>NI-DAQmx SCXI Chassis>PXI-1010 (SCXI). Choose "Using PXI Backplane" as the SCXI Communication Mode. When the SCXI Chassis Configuration window appears, select to Auto-Detect All Modules. Your SCXI-1120D modules and SCXI-1169 module should now appear. Select your accessory and configure any Details...
Let me know if you have further questions!
Chad Erickson
Switch Product Support Engineer
NI - USA
03-28-2007 06:44 AM
When I follow the directions and the Create new SCXI chassis appears chassis communication and communicating SCXI module slot is greyed out. It does show the 6070E card and in slot 8 which is correct. however it is grayed out. The other info, chassis address, SCXI commmunication mode, and the autodetect appear correctly. I then clicked the save button and another window appears. In red the message says chassis is empty. I then manually entered the correct boards in the correct slots. SCXI-1120D in the first two slots and the SCXI-1169 in the third. It looks like it has created the chassis. The chassis test fails. The message is large but says chassiserror -200587 occured. The selftest for the 1120D boards does come up. the switch board does not.There is a lot of verbage but at the bottom it talks about if you are using chassis with traditional DAQ then init with traditional DAQ. Is this what I should do?
Rick
03-28-2007 06:57 AM
03-29-2007 09:56 AM - edited 03-29-2007 09:56 AM
Message Edited by Neil S. on 03-29-2007 10:01 AM
Message Edited by Neil S. on 03-29-2007 10:06 AM
03-29-2007 10:20 AM
03-29-2007 10:34 AM
03-29-2007 12:12 PM - edited 03-29-2007 12:12 PM
Message Edited by Neil S. on 03-29-2007 12:13 PM
