In my systems, there are SMU PXI 4030, PXI Switch 2532, PXI DMM 4071.
Both SMU and DMM will connect to DUT via PXI Switch. Handshaking between DMM and Switch is available yet handshaking between SMU and Switch is not.
At the begging scan list including all connections (connections between SMU and DUT, connections between DMM and DUT) will be comminted into Switch.
Problem is:
The first 5 steps of scan list will advance with handshaking between Switch and DMM. The sixth step of scan list will be used for connecting SMU and DUT, so at
this time, DMM can't shake hand with Switch and software trigger to Switch shall be used. But how can I perform this with best solution? I have 2 solutions:
Solution 1:
1) Configure sample count of niDMM Configure Multi Point as 5. DMM will stop sending trigger to Switch after measuring 5 samples (Is this configuration right? Do I need to configure trigger count?).
2) Stop the Switch task (DAQmx Stop Task). Change the Switch advance trigger type from Digital Edge to Software.
3) Use software trigger in the following steps of scan list.
Solution 2:
1) At the begging only 5 steps of scan list were committed into Switch.
2) After DMM measurement ends, Stop the Switch task.
3) Configure the following scan list with DAQmx Switch Creat Scan List
4) Commit the scan list into Switch.
Which solution makes sense?
And another better solution?
