Sir,
I am facing following problems in measurement of analog signal with Relay Multiplexer (NI-2503) & Digital Mutimeter(NI-4060)
Please see this attached file and problem description is as :
I am generating some analog signals by custom Built card using with analog card (PXI-6713). then for self test of these signals, these are given as input to one another custom built card (self test card,
contaning Multiplexer ICs) after selecting signal it goes to output connector, then from o/p of self test card, these are input to 3 channels of NI-2503 then its output is connected to DMM.
Some times, It gives perfect result by using attached vi file in this mail But some times it reports the following problems and no result
comes. What may be the reason.
1) Error BFFA4001 occured at niswitch initialize.vi
Problem Reason :
Unkown status value 0xBFFA4001
2) Error BFFA2003 occured at nidmm fetch mutipoint.vi
Problem Reason :
Max Time exceed before operation completed
Please see, what mistake is there, as it is very urgent metter for clearance of project by QC for delivery after 7 days. This problem should be resolve
completely.
Jitendra
