Switch Hardware and Software
DAQmx SCXI-1167
Reading over http://zone.ni.com/devzone/cda/tut/p/id/3308 it states rather non-challantly that "The PXI-2567 and SCXI-1167 can also be programmed using the NI-DAQmx DIO functions."
Does this mean that the following (simple example) would work with the SCXI-1167 installed in an SCXI-1001 chassis?
What if the SCXI-1167 was connected to the PC via the USB-1600 module?  I am inclined to think it WOULD because of the SCXI-1600 Data Sheet statement:
"The SCXI-1600 is a full-featured 16-bit digitizer and control module for SCXI analog input, analog output, digital I/O, and switching modules."
Message Edited by RVallieu on 04-09-2009 05:21 PM
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(7,618 Views)
Accepted by topic author RVallieu
Hello!
Thank you for posting to the NI Forums! I set up the hardware today and succescully ran the code you posted. So, you are correct, it can be done!
Margaret Barrett
Digital Multimeters and LCR Meters
(7,601 Views)
Thanks for verifying that for me!
(7,585 Views)
