Switch Hardware and Software
Connecting 5 PXI-2527 to 4070
What is the best way to connect 5 PXI-2527's to create a signal MUX that goes to a PXI-4070 DMM. I really need the high voltage.
Leo
(7,437 Views)
Hi Leo,
The PXI-2527 has a front-mounting terminal block (TB-2627).  Bare wire is used to connect to the TB-2627 screw terminals.  Using additional bare wire, you can externally connect (daisy-chain) the COM lines together to expand the multiplexer across multiple PXI-2527s.  Remember to select the wire gauge so you can insert more than one wire in the COM screw terminals.
Spec'd clamp opening size: 0.065 x 0.067 in (1.65 x 1.7 mm)
Spec'd maximum wire diameter (for one wire): 0.65 in (1.65 mm)
Let me know if you have further questions!
Chad Erickson
Switch Product Support Engineer
NI - USA
Message Edited by Chad PSE on 03-03-2009 10:19 AM
(7,417 Views)
