08-29-2005 08:44 AM
08-29-2005 08:59 AM
the niSE session talks to underlying IVI drivers using the IVI Switch session underneath, so any additional opening of IVI Switch session to the same device will cause the two driver sessions (that keep the information about the state of the hardware connections) to be either one or both out of synch with the actual hardware state). Because of the architecture of the underlying IVI drivers, niSE session cannot know if and what someone did to the instrument using IVI Switch session.
Therefore, it is not adviseable to use IVI Switch session while having another session open to the same device. If you need to use the invasive operations - which is anything that changes the state of the device, such as Reset and possibly self-test (self-test may be implemented as an operation that cycles relays and it may not but you can't be sure), you must make sure that one session is open and closed before another type of session is open.
The ni Switch Executive Open Session calls IviSwtch_init (with ID Query and Reset set to true) and CloseSession closes the IVI Switch sessions with the call to Close. The niSE session does not make calls to either reset or self-test explicitly.
01-16-2008 04:51 PM
01-16-2008 11:26 PM
01-17-2008 10:55 AM
01-17-2008 01:04 PM
