02-15-2008 10:31 AM
02-15-2008 10:46 AM
kph:
To back up and restore a virtual device programmatically, call the niseCfg_Export() and niseCfg_Import() methods.
These are available in LabVIEW under the Measurement I/O -> SwitchExecutive -> Configuration palette. If the palette doesn't exist, be sure to select LabVIEW support on install. If not, rerun the NI Switch Executive installer.
For C, they are in C:\Program Files\National Instruments\Switch Executive\API\C\nise.h. If this doesn't exist, be sure to select C/C++ Support on install. If not, rerun the NI Switch Executive installer.
Brian
