Switch Hardware and Software
Are there labview drivers for setting parallel port pins hi or low?
My application is to open or close relays and I was wondering if the parallel port could be used in this application by setting the pin voltages high or low to control the relays.
(8,670 Views)
Please see the following document from the NI web site on dealing with the parallel port:
Using the Parallel Port in LabVIEW
Randy Hoskin
Applications Engineer
(8,670 Views)
