The Time-Frequency Domain AnalysisOnline Laboratory Utilizing the EMONA DATEx
University: Makerere University
Team Member(s): Arthur Tumusiime Asiimwe
Faculty Advisors: CosmasMwikirize, Paul Isaac Musasizi, S.S. Tickodri-Togboa and Alfred. Mwambela
Email Address: atasiimwe@gmail.comor atasiimwe@tech.mak.ac.ug
Title:Integrating the Frequency DomainFunctionality of the EMONA DATEx into the iLabs Shared Architecture
Description:
The developed online laboratory provides an interface where fourinstruments (Function Generator, Oscilloscope, Variable power Supply and theDynamic Signal Analyzer) can be used to analyze the circuit under test. Theuser is able to observe, in real time, the effect of changing variousparameters of the message signal and the carrier signal to achieve the desiredmodulation. The results are displayed in both the time and frequency domainsand the user is able to vary the Dynamic Signal Analyzer settings, to get thedesired output. Once integrated into curricula, the developed online platformshall supplement the conventional Laboratories where the requisite infrastructurehas been established.
Products:
Laboratory VirtualInstrumentation Engineering Workbench (LabVIEW)
National Instruments Educational Laboratory Virtual InstrumentationSuite (NI ELVIS II+)
EMONA Digital AnalogTelecommunications Experimenter (DATEx)
The Challenge:
It is important to note that ofthe twelve instruments that are listed on the NI ELVIS mx Instrument launchershown in Figure 1, the DSA does not have an express VI that can be used toconfigure it in LabVIEW as illustrated in Figure 2.
The Solution:
A software equivalent of the DSAwas developed basing on the NI ELVISmx Dynamic Signal Analyzer Soft Front Panelshown in Figure 3 and the block diagram is shown in Figure 4. The DSA basicallyimplements the Fast Fourier Transform on the time signal and gives a plot ofthe RMS averaged Power Spectrum / Power Spectral Density (PSD) against frequencyof a single channel. Ofparamount importance is the FFT settings and Averaging section of the DynamicSignal Analyzer soft front panel. This enables the user to customize the FFTand averaging performed on the acquired data. The Frequency Span specifiesthe measurement range that starts at DC and extends to the Frequency Spanvalue. Resolution (lines) determines the length of the time-domain record andthe number of samples to be acquired. The user specifies the time-domain windowto use using the Window drop down menu. Customization of the display graph isachieved by the Frequency Display and Scale Settings section of the DynamicSignal Analyzer. With these settings, the user can configure the displayedunits for the magnitude plot, the display mode and axis maximum and minimumvalues.
The NI ELVIS II+ platform is remotelycontrolled from computer; through LabVIEW therefore a VI custom made for theModulation experiments used in the iLabs Shared Architecture to support the Time-FrequencyDomain Analysis Online Laboratory Utilizing the EMONA DATEx. The NI ELVIS II+ /DATEx bundle shown in Figure3, enables remote access to the instruments which are commonly used in aCommunications Engineering laboratory (Function Generator, Variable Power Supply, oscilloscope and the DynamicSignal Analyzer). The EMONA DATExis an add-on board for the NI ELVIS™ platform that allows a broad range ofintroductory telecommunications experiments to be implemented. It also providesa hands-on learning environment for students to see the fundamental math andtheory of telecommunications implemented with real-world electrical signals.
Hello there,
Thank you so much for your project submission into the NI LabVIEW Student Design Competition. It's great to see your enthusiasm for NI LabVIEW! Make sure you share your project URL with your peers and faculty so you can collect votes for your project and win. Collecting the most "likes" gives you the opportunity to win cash prizes for your project submission. If you or your friends have any questions about how to go about "voting" for your project, tell them to read this brief document (https://forums.ni.com/t5/Student-Projects/How-to-Vote-for-LabVIEW-Student-Design-Projects-doc/ta-p/3...). You have until July 15, 2011 to collect votes!
I'm curious to know, what's your favorite part about using LabVIEW and how did you hear about the competition? Great work!!
Good Luck, Liz in Austin, TX.
Hi - Can you please list out the products that you used for your project? Thank you!
