Student Projects
Sonar parking aid
Purpose
                Implement a sonar proximity sensor for aiding the parking of a car
Equipment:
  • Maxbotix LV-EZ1 - $24
  • Red LEDs < $1
  • 6 wires < $1
Set up Hardware:
  • Connect the sonar range finder
    • Connect analog in to analog out 1 on the myDAQ
    • Connect ground to analog ground on the myDAQ
    • Connect analog out to the analog in 1+ on the myDAQ
    • Connect analog in 1- on the myDAQ to analog ground on the myDAQ
  • Connect the LEDs
    • Connect the positive side of the LEDs to analog out 0 on the myDAQ
    • Connect the negative side of the LEDs to analog ground on the myDAQ
Software Instructions:
  • The VI allows you to set the min distance, if the range is within this distance the LEDs will be on
  • You can see the values the sensor is returning in inches on the chart on the front panel
Images:
Video:
coming soon
Contributors
