Sensor Type: Triple Axis Accelerometer
Manufacture/Model Number: ST: LIS3LV02DQ
Link to Sensor: https://www.sparkfun.com/products/retired/758
LabVIEW or C: LabVIEW
Version of LV: 2013
Description/Instructions on how to use this example:
This example reads data from ST LIS3LV02DQ Triple Axis Accelerometer Sensor, processes the data and displays the data.
1. Connect the sensor to myRIO.
ST LIS3LV02DQ Triple Axis Accelerometer Sensor myRIO
Vdd +3.3V
GND GND
SCL Connector A/SCL
SDA Connector A/SDA
2. Check the myRIO target IP Address in the project and make sure the target IP Address is correct.
3. Run this VI.
Code: Attached Triple Axis Accelerometer.zip
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
