Sensor Type: Compass
Manufacture/Model Number: Honeywell HMC6343
Link to Sensor: http://www.digikey.com/us/en/ph/honeywellssec/hmc6343.html
LabVIEW or C: LabVIEW
Version of LV: 2013
Description/Instructions on how to use this example:
This example reads data from HMC 6343 3-Axis Compass Sensor, processes the data and displays the data on the waveform chart.
1. Open myRIO Honeywell HMC6343 3-Axis Compass Sensor.lvproj
2. Connect sensor to NI myRIO
3. Open and run Main.vi
Wiring Diagram of Sensor to myRIO:
Honeywell HMC 6343 myRIO
V+ +3.3V
Gnd Gnd
SCL Connector A/SCL
SDA Connector A/SDA
SCL pull-up register to VDD
SDA pull-up register to VDD
Code: NI myRIO Honeywell HMC6343 3-Axis Compass Sensor.zip attached
