I am trying to experiment a PID control of DC motor as given in the Resources document.
I would like to know what is the specification of the Hall effect sensor that can be used.
Thanks in advance.
Hi Mani-Tech - You will need to use a digital hall effect sensor to use the counter on the DAQ board to count the pulses. I'm including two sensors we used to complete the project for your reference below. Good luck!
Operating Supply (Input) Voltage 5Vdc
Output Voltage 5V
Mounting Style: Through Hole
SS466A Honeywell Digital Position Sensor Hall Effect 3Pin
A3212 Allegro Micropower, Ultrasensitive Hall-Effect Switches
