Sensor Type: HYT221, HYT271, HYT939 - Temperature and Humidity Sensor
LabVIEW or C: LabVIEW
Version of LV: 2013
Description:
HYTxxx is a digital temperature and humidity sensor. HYTxxx sensor uses the IC2 protocol.
Download HYTxxx datasheet from web for more information and specifications.
Instructions:
The API is implemented on RT.
To get the measured temperature and humidity values from HYTxxx use API functions in API folder from 'HYTxxx.lvlib’.
There is also 'Example – HYTxxx (RT).vi' in Example folder.
Wiring Diagram:
