Student Projects
Efficient Wireless Data Transfer for Realtime Greenhouse Management Using IEEE 802.15.4/zigbee protocol for Student Design Competition 2013
Contact Information
University: Dr. N. G. P Institute of Technology
Team Members (with a year of graduation) and (with year of graduation 2013):
PRAVEEN KUMAR N & TEAM
(1) ABDUL WAHAB,  (2) N.PRAVEEN KUMAR, (3) S.SHIBI PRASANNA, (4) P.PRADEEP.
Faculty Advisers: Ms K.KOTHAVARI
Email Address:
meetnpraveenkumar@gmail.com
Submission Language: English
Project Information
Title: Efficient Wireless Data Transfer for Realtime Greenhouse Management Using IEEE 802.15.4/ZigBEE protocol
Description:
        In our day to day life agriculture plays a vital role, the quality and cost are the major problem in food products, there is a greater demand for food product due to drastic population growth, our world population is expected to reach 9.1 billion people by 2050, Agricultural and power production demand increases rapidly (survey by MICCA). The environmental issues such as temperature, humidity, soil and pest are the factors affect the crop growth and productivity up to 30% (IFPRI).The Greenhouse with an perfect control system helps to over come this problem.
Products
SOFTWARE:
  • LabVIEW 12 SP1
  • Lab VIEW VISA
  • Multiuse( Circuit simulation software)
HARDWARE:
  • Microcontroller(pic16F877A)
  • LM35 (temp sensor)
  • Humidity sensor HSY220 sensor.
  • Soil moisture node (Conductivity rod ).
  • ZigBee Transceiver (CC2500).
  • Solar panel(16W) and battery (6v).
  • Actuators(motor, water jetter, heat blower, sprinkler and cooler/exhaust fan )
The Challenge
Challenge is to make a controlled algorithm to maintain the indoor environment without any effect by external condition for different types of crops without any physical interuption by user . The precise controlling of indoor climatic is a main challenge in green house management.
The limitations are large green house structures should be used for improved climatic control. Initial implementation cost is high because of actuators used.
In Research application,case study can be done for different climatic condition for specific species of crop. hence the rate of vegitation can be enormously developed, so a data base management is done with the help of LabVIEW11 hece a user can retrive and analyse the data at any time.
The Solution
With the help of virtual tool such as LabVIEW, embedded with sensors, the proposed design is to measure, acquire and control user required parameter. An autonomous system contribute improved and constant yield.
Autonomous system which is proposed is an embedded control system.  The system can run independently without any external power supply for a 6-8 month using solar energy.
System maintains stable climatic condition which helps in improving the growth rate of the crop. Each plant has certain parametric set values which can be predefined by user in the virtual software. Thus LabVIEW is programmed such that the constant condition is maintained with the help of actuators such as Heaters, Humidifiers, and Sprinklers etc.., IEEE802.15.4/ZigBee does the wireless communication between greenhouse nodes and remote monitoring node.
Pests and pathogens are controlled by changing the temperature of the chamber and also through water jetting. By controlling the temperature, growth of the pests can be reduced.
To have effective energy harvesting, two solar panels (WE-1) is coupled with the nodal block which makes system works independently.The estimated power consumption of each (electronic node)EN in peak sunlight the amount of energy harvested for a 16W solar panel produces 16W/hr. for 1000W panel harvested 1000W/hr with respect to area.
Here a 6V battery connected with 16W solar panel is more sufficient to maintain the node block power, hence battery never get down.
WORKING & RESULTS:
                  Here i have shown,the overall arrangement of the approach, which are clearly taged.
          The hardware of the node unit, this is placed inside the chamber.
     corresponding test results of node unit(the LM35 & HSY-220 sensor output):
                                                        The vrms is the output value
                    SOIL MOISTURE UNIT output:
PC UNIT:
               As per the flow these node unit data, is transmitted to PC unit to Labview via serial communication.
LabVIEW Front panel:
                    Data are collected from each node, displayed and controlled respectively with the input.
Control Unit:
               hardware of control unit is shown, each actuators are controlled with the obtained value.
Data Sheet:
     sequence of data is stored in an spread sheet, this is used for DBMS, for future reference and analysis this is used.
Plot From the obtained data:
               from the data sheet, the corresponding plots where made for each parameter.
     Green house chamber implemented:
                              A test chamber(10*10*12ft), system is successfully implemented.
Applications:
This system can also be applicable for outdoor agricultural monitoring, Irrigation management and solar dryer controlling. It has a feasible form of applications such as monitoring industrial environment (such as highly dangerous chemical factory monitoring) . Depending up on the application the actuators can be added or replaced for precise controlling of the parameters.
FESIBILITY: The overall cost will be around Rs8,000, which will be more usefull to low level and medium level farmers and it can be easily implemented and programable. This approach will leads to next generation of green House farming, This can be Comertialized and upgraded depending on the needs of the farmer. These are the Economic and Technical Fesibility of the concept.
Others, please see the attached files, i have described testing and results breifly.
Video Link: http://www.youtube.com/watch?v=F4BJC9u_73k&feature=youtu.be
Comments
NPK
Member
Member
on
Remote monitoring and environment controlling of agriculture green house chamber is achieved and this prototype is deployed in the video.
This system is more feasible and more reliable for all farmers.
by maintaining climatic condition high yield can be obtain, the graphical LabVIEW interface displays data and its stored in excel sheet it is used for case study purpose.
this system can be implemented in areas where it is very rare to vegetate and extreme cold regions.
new video:   http://www.youtube.com/watch?v=7FLyk08vGb0&feature=youtu.be
niyantra12 video: http://www.youtube.com/watch?v=Rw65t4XT5fA
ece123
Member
Member
on
good work, and all the best.
ece123
Member
Member
on
adopting new technologies in agriculture is very important now a days, this makes a benchmark for future agriculture.
muthu7654
Member
Member
on
i am very happy that your team is doing fine, keep it up , and present well ..... all the best...
rahulmur
Member
Member
on
develop this concept, make it as comertial .....
subaashtiru
Member
Member
on
good luck tsf....
mithunece
Member
Member
on
nice work , upload pictures and the paper u have published yaar.....
NPK
Member
Member
on
thank you all for supporting me, ill do my very best..
narmatha
Member
Member
on
gud luck bro....
sandy7573
Member
Member
on
all the best to your team. perform well
NPK
Member
Member
on
pdp
Member
Member
on
Nice idea...... is this reliable ????
RAGUNATH
Member
Member
on
Good Al te best.................
guru1238
Member
Member
on
good boyz......................
NPK
Member
Member
on
yes it is very much reliable to medium level and low level farmers and user can easy understand the concept.....
Yohi1
Member
Member
on
REally inspiring
VIJAYANTONY
Member
Member
on
Wonderfull Project for real time Implementation
SatheeshPSG
Member
Member
on
A gud try.. Should be appreciated and also to be applauded.. All the best guys!!!
sanshivan
Member
Member
on
now-a-days there are less people who take project in this AGRI Field, so i appreciate your team to choose this field and idea.
diliptamil
Member
Member
on
it will be useful for the future enhancement in agriculture. nice work.
AadeshK
Member
Member
on
This will be an inspiration for others who would like to carry out their project in agriculture. All the Best guys.
StarAG
Member
Member
on
Excellent project! Hope you win the competition!
subaash44
Member
Member
on
Good Work da...Hope you will win this competition,all the best!
DilipCool
Member
Member
on
Excellent Work,.!! Best of Luck!!
SSP110
Member
Member
on
NICE WORK..........ALL THE BEST
abh
Member
Member
on
Very good keep it up
Arundoss
Member
Member
on
All the best. New idea !
gha
Member
Member
on
Good Work Guys!
dgf
Member
Member
on
Best of Luck guys
abrahamabrahama
Member
Member
on
One of the excellent Agriculture-based Projects! Awesome! All the best!
ArunGaneshU
Member
Member
on
May Allah bless you with good projects like this! Insah Allah!
sang11
Member
Member
on
goog wor da.nice keep it up. all the very best
GovindaGovinda
Member
Member
on
Ealu kondalavana! Venkataramana! Govinda Govinda! Project chaala baaga undhi baava gaaru... All the best mee manchi friend thegara undi!
Silksmitha
Member
Member
on
Innovative!
davidthanksgod
Member
Member
on
Ei thumara project ko bahooth acha hein!
raindropsareawe
Member
Member
on
One of the new inventions! Jai Jakkamma!
PommieMbangwa
Member
Member
on
The thinking is awesome maan!
DanielWDolothy
Member
Member
on
Iznenađujuće projekt! Neka vas Bog blagoslovi!
sukanesh
Member
Member
on
All the best guys
varun1990
Member
Member
on
Keep going guys... good work
pooneshthemeow
Member
Member
on
A cat cant live without milk. Same way, an Engineer cannot live without his project! Hats off to you!
McLaughlindanny
Member
Member
on
Hey dude! What an awesssssome project maaan! Its raining in Guam when I see your project explanation. Very good video maan. You hit your project like Gayle hit 6 out of the stadium maan. Good luck!
Vijaysethupathy
Member
Member
on
Wonderful!
ajithkumaran
Member
Member
on
Amazing technology by the team! Good luck!
vankamshalu
Member
Member
on
Very nice work!
josephdavila
Member
Member
on
Exquisite!
AGADA
Member
Member
on
Marvelous!
Thedarkknight
Member
Member
on
Fantastic!
dandaanadarna
Member
Member
on
Wow wow wow! Mr. Praveen kumar has done a great job!
dakaltimandayan
Member
Member
on
FAntasic maan!
Contributors
