Student Projects
Design and Construction of an Optical Classifier Prototype
Contact Information
University: Universidad Santo Tomas
Members of the Group: Fabián Alberto Herreño Cuestas.
Directed by: Ing Davis Montenegro and Ing Leonel Giraldo
Emails: davismontenegro@usantotomas.edu.co; leonelgiraldo@usantotomas.edu.co
Project Information
Title: Design and Construction of an optical classifier prototype.
Description:
Design of an optical bottle classifier prototype supported in the LABVIEW programming platform that emphasizes simplicity, speed and efficiency
National Instruments Products used in the project:
LabVIEW 8.0
NI USB-6008
NI PCI 1411
NI IMAQ Vision
NI DAQmx
The Challenge:
Design and implement a flexible system, efficient and economically attractive to academic and industrial sectors to control the classification of integrated packages of the same shape and size that is practical and easy to use, applied to a prototype that shows the virtues of design and programming proposals and the integration of the acquisition, signal and image processing.
The Solution:
Designed, developed and implemented an image processing and signal control system, using LabVIEW. The system is able to acquire through a digital camera and a position sensor connected to a NI PCI1411 card and recognize different packages or patterns, measurements of these with the tools provided in the IMAQ Vision module,
which determines its quality and their selection is done by writing a signal via the NI USB 6008. Using the NI-DAQmx we can control the pneumatic cylinders which redirected the bottles according to the restrictions defined previously by the user.
Comments
jcallaway
Member
Member
on
Hey there,
Thank you so much for your project submission into the NI LabVIEW Student Design Competition. It's great to see your enthusiasm for NI LabVIEW! Make sure you share your project URL (https://decibel.ni.com/content/docs/DOC-16405) with your peers so you can collect votes via "likes" for your project and win. Collecting the most "likes" gives you the opportunity to win cash prizes for your project submission. I'm curious to know, what's your favorite part about using LabVIEW and how did you hear about the competition?
Good Luck, Jessica in Austin, TX.
Contributors
