Sensor Type: BMP085 (GY-65) - Atmospheric Pressure and Temperature Sensor, Altimeter
LabVIEW or C: LabVIEW
Version of LV: 2013
Description:
BMP085 is a Barometric Digital Pressure Sensor.
Typical applications are:
You can either use the BMP085 sensor with the breakout board GY-65 or you can build your own circuit. In the BMP085 data sheet you can find the circuit (search for BOSCH BMP085 datasheet, typical application circuit).
The ‘BMP085 (GY-65) Library’ use the I2C protocol. You can use I2C Transfer Rate ‘Standard Mode (100 kbps)’ or ‘Fast Mode (400 kbps)’ and you can select between four different oversampling modes (measurement accuracies):
For more information and specifications check data sheet.
Instructions:
The API is implemented on RT.
To get the measured pressure and temperature values from BMP085 use API functions in API folder from 'BMP085 (RT).lvlib’.
There is also 'Example – BMP085 (RT).vi' in Example folder.
Wiring Diagram:
Grear API, thanks!
Great!
Hallo Wolfgang_Z.
Connection diagram above: Was it not necessary to connect pullup resistors from the I2C lines (SCL & SDA) to the supply VCC?
Regards
Malan
Hi Malan,
For the BMP085 (sensor only) you need additional resistors. Please check out the BMP085 datasheet for that.
The picture above shows the Breakoutboard GY-65. The breakoutboard includes the BMP085 and the resistors.
Wolfgang
can i connect BMP180 to myrio 1900
