Smartphones, Tablets, and Mobile Devices Discussions
Reply
How to debug an arm assembly in eclipse with adt & android-ndk in linux-64bit platform?
Hai... Iam new to android-ndk.
Iam trying to build pure c code by using android-ndk finally its working.
Now Iam trying to call assembly file from that c code but Iam getting errors.
Iam using Linux_GCC
/* This is my Android.mk file */
LOCAL_PATH := $(call-mydir)
include $(CLEAR_VARS)
LOCAL_MODULE := Sample
LOCAL_SRC_FILES := test.c assembly.S
LOCAL_ARM_MODE := arm
LOCAL_LD_LIBS := -llog
include $(BUILD SHARED_LIBS)
TARGET_ARCH_ABI == armabi-v7a
/* This is my application.mk file */
APP_OPTIM := debug
APP_ABI := armeabi armeabi-v7a x86
APP_STL := gnustl_static
/* This is my c file */
extern int assembly(int a);
int main(void)
   int a = 5, b = 10, c, d;
   c = a * b;
   d = assembly(c);
   printf(" d = %d", d);
   return(0);
/* my assembly file */
.text
.global assembly
assembly:
   stmfd sp!, {r4-r12, lr}
   add r4, r0, r1
   mul r3, r0, r2
   ldmfd sp!, {r4-r12, PC}
   bxlr
In order to build assembly I added following
Project --> Properties--> c/c++ build --> settings
GCC Assembler: added -arch i386 -g after as
GCC C Compiler: added -m32 after gcc
GCC C Linker: added -m32 after gcc
in debug configuration settings i have  select c/c++ application as default/Sample
while building project it is showig error as Sample/default/Sample is not found.
I reffered few sites in those i observed they select c/c++ application as project/obj/local/armeabi/app_process but i didn't found app_process in that path in my project.
Hope somebody will help me regarding this.
THANKS
(2,410 Views)
Re: How to debug an arm assembly in eclipse with adt & android-ndk in linux-64bit platform?
You definitely need to review what you did so far:
TARGET_ARCH_ABI=armabi-v7a
This indicates a fairly recent ARM CPU.
The assembly code also looks like ARM. Then -arch i386 and -m32 make no sense at all, although not sure -m32 would hurt but there is AFAIK definitely no -m64 target for armabi-v7a so far.
Rolf Kalbermatter
Averna BV
LabVIEW ArchitectLabVIEW ChampionLabVIEW Instructor
(1,349 Views)
