Smartphones, Tablets, and Mobile Devices Discussions
Reply
Best solution for LabVIEW program on Tablet/Phone
I have this LabVIEW program for intelligent charging of Electric Vehicles (EV) which communicates with the hardware (charging station and EV) via c-RIO modules. The PC has 2 LAN cables, one connected to the internet and another to the c-RIO system. I want this program to be available on a tablet/ mobile phone (the tablet being tested for the time being is Surface RT with Windows 8 OS). I have ruled out the following options for the reasons mentioned:
1) Remote front panels: Surface doesn't support LabVIEW Run Time Engine.
2) LabVIEW Web UI Builder: Although it says that Microsoft Silverlight is supported on Windows tablet, I couldn't find anything on the RT Store.
3) LabSocket System: It's extremely expensive and only available for LabVIEW 2013. My program runs on LabVIEW 2012.
4) Webpager: I've used the trial version. Although it works for smaller VIs (with control difficulties), it doesn't show anything on the webpage for the main program (which is a state machine with multiple tabs and the tabs can only be accessed in a sequential manner). Also it works on PC but not on tablet.
There are few other options which I have few queries about:
1) Data Dashboard: It seems to be the best option so far. So, I gathered the system and the tablet should be within the same internal network. For that should I connect the c-RIO and the tablet via a common network or the PC and the tablet? will it have time lapses in graphs if I switch to and fro the pages?
2) VI Remote: Can an iPad/ iPhone/ iPod be used to remotely control the program using the VI Remote toolkit?
3) T4SM has this product called Remote Control for LabVIEW. How useful would the product be for this application? Would it be compatible with the existing tablet?
Please assist me in deiciding which the most feasible option is. Thanks.
(5,321 Views)
Re: Best solution for LabVIEW program on Tablet/Phone
Hi Shreya,
It sounds like Data Dashboard is a good solution for what you are currently trying to accomplish. It is interesting to see your run-down of other options.
One other possibility I would like to mention to you was designed for monitoring cRIO's remotely from the web. It is called Cloud Dashboard, and is currently in NI Labs (free, but still in a beta mode). Cloud Dashboard provides a polished javascript-powered UI that you can log into to see your devices. Let me know what you think:
https://decibel.ni.com/content/docs/DOC-38359
- Joey
Joey S.
Senior Product Manager, Software
(2,895 Views)
Things to keep in mind:
  • The Windows 8 version of Data Dashboard doesn't support control at all. Only indicators are supported.
  • In the Windows 8 version charts that aren't visible don't record new data so if you switch to another page for a while and then switch back there will be a gap in the data.
Both of those issues are resolved if you use the iPad or Android tablet versions of Data Dashboard (2.x).
(2,895 Views)
Have a look on www.wezarp.com .
Wezarp for NI LabVIEW allows a LabVIEW application to be controlled by a remote device such as a tablet, a smartphone or a remote computer.
iOS iPad/iPhone and Windows tablets are supported.
Best regards
Jeff from Wezarp team
(2,895 Views)
Hi Jeff,
I'd encourage you comment on this document here in the web development community to share about Wezarp:
https://decibel.ni.com/content/docs/DOC-41454
Best,
Joey
Joey S.
(2,895 Views)
Hi Joey
Thank you very much for this advice.
I'm gonna comment in a minute!
For information, Wezarp for NI LabVIEW will be on the LabVIEW tools Network within 24-48h
See the following link: http://sine.ni.com/nips/cds/view/p/lang/en/nid/213167
Would it be possible to have a direct link from your document like the one for LabSocket for example
Best regards
Jeff
Jean-François DAVID
jf.david@appando.net
+33 607 03 42 36
Le 23 avr. 2015 à 18:59, JoeySpinella a écrit :
Community
created by JoeySpinella in Smartphones, Tablets, and Mobile Devices - View the full discussion
Hi Jeff,
Best,
Joey
Reply to this message by replying to this email -or- go to the message on Community
Start a new discussion in Smartphones, Tablets, and Mobile Devices by email or at Community
(2,895 Views)
