I want to turn on a solid state realy using a DO line. Once turned on, it shall remain on until turned off.
I did DAQ Assist > Generate Signal > Digital Output > Line Output > DO 0 > 1 sample on demand.
I made a boolean constant, set to True, and connected it to DAQ Assistant Data, expecting it would output 5 V signal . I get a bad wire. What did I do wrong? Thanks.
