SignalExpress
synchronise NI 9239 & NI USB 8473 with Signal express
Hello, I have a Cdaq 9174 chassis with an NI 9239 module (analogue input at 50Khz/ch) with Signal Express.
And I wanted to know if we could acquire this four inputs synchronised with datas from CAN connection by using a NI USB 8473 ?
Many thanks.
Patrick.
Message 1 of 8
(5,642 Views)
hello patlegain,
Are you using aVI import in Signal Express in order to user the 8473?
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 2 of 8
(5,624 Views)
Hello, no we don't use VI.
We are just starting with NI systems and we're just testing with Signal express different kind of acquisition to know the opportunities.
Does we need absolutely to use VIs to acquire datas from the 8473? Is it very difficult to do?
Many thanks!
Patrick
Message 3 of 8
(5,622 Views)
For me you can't use the driver NI-CAN is not compatible with Signal Express. The Only way you could use it with SE, is to pass through LabVIEW VI.
You'll find in the below link the way to do it.
http://digital.ni.com/public.nsf/allkb/359D14941D6936E98625729D008387D5
I advise you to stay in LabVIEW this kind of program. It's easier.
Best regards.
Message 4 of 8
(5,619 Views)
Thanks for your advise, I saw that a CAN module for compact rio already exist, the NI 9862. I saw that this solution is better with hardware sync.
Is this one is directly workable by signal express, or does we need VI anyway?
Message 5 of 8
(5,615 Views)
SignalExpress can only be use with those drivers:
NI-DAQmx /NI-SCOPE / NI-FGEN / NI-HSDIO / NI-HWS / NI-DMM / NI-DCPower / IVI Driver Toolset.
SE does not support the NI-XNET driver that the 9862 runs on so it is not compatible. And i'm not sure that you can run a VI that uses this drivers on SE.
Best regards.
Message 6 of 8
(5,613 Views)
OK. We've found a solution, we used the shared variables from LABVIEW to transmit to signal express.
Thanks!
Message 7 of 8
(5,554 Views)
You are welcome.
best regards.
Message 8 of 8
(5,551 Views)
