11-14-2016 11:58 PM
Can I use USB 6009 to generate sine wave by using only Signal Express ?
11-16-2016 09:51 AM
Hi Kunso,
Yes you can, you can find a quick example of how to do that here. It also includes an example project for you to download if you need.
11-24-2016 07:21 AM
Thanks Euge Or Pat
The amplitue of signal quite very small. So, how I can increase amplitude to 2 volt because I found some error when I tried it.
11-28-2016 04:03 PM
What do you mean when you say you're getting some error? If the error is at a very small voltage range then it might be a resolution issue of your device.
