04-02-2012 02:40 PM
I'd like to synchronously acquire both digital and analog data using lower-level DAQmx VIs. For some reason, I cannot configure correctly my difital task.
Here is the Vis for this project that is aimed to record voice and press-button board.
Thanks for helping
04-03-2012 07:43 AM
You accidentally posted this to the wrong forum. Repost in the LabVIEW forum and you should get a swift reply. Unfortunately, my DAQ skills are not good enough to give you much help.
04-03-2012 12:35 PM
Actually, it will be ideal to post this thread in the Multifunction DAQ board. Plus, there is an example called "Multi-Function-Synch AI-Read Dig Chan.vi" at the NI Example Finder under Hardware Input and Output»DAQmx»Synchronization»Multi Function that does exactly what you are looking for. A piece of advice, the shipping examples are built using DAQmx low level APIs so it would be a good Idea to check there first, plus. I would recommend not to use the timed loop unless you are running your application in a real time OS. Good luck!
