I am trying to use a NI 9237 with a NI cDAQ-9172 to measure pressure using a pressure transducer. When I plugged the 9237 into the cDAQ it was not recognized. As I remember with this piece of eqiupment, once a module is plugged in it should be recognized and configured. Any ideas?
I'm wondering, do you have the driver installed? As well, is your chassis recognized in Measurement and Automation Explorer? Does the New Found Hardware issue ever pop up when you connect your device? Thanks!
