09-04-2007 08:52 AM
09-04-2007 12:50 PM
09-05-2007 01:54 AM
Yes for the empty dataview problem try this:
Create a project wich measures for example 3 signals, create a dataview with 3 views in, one for each signal,
save the project.
Then open that project again and in my case there is then just one Dataview with no more subviews anymore,
also there is no signal bounded to the view anymore, so in fact I'm left with just an empty Dataview...
I normally measure a number of signals at a time, 8, 12, or so and I define datviews (tabs) with the raw signals, then with the
filtered versions, then with fouriers for example, that is one of the main reasons We buyed SE because it gives us this nice
view on different signal aspects in different tabs, once the project is running no problems (exept for thos damn Y scale labels overwitten
off course) but when I save the project and reopen it again, from the 5 tabs with lets say 3 views each only one remains intact,
the other views seem to have lost their layout or subviews or what you call it....
I can reproduce this error every time I save and re-open a project... but one time if I have 3 tabs with dataviews it clears to views,
the other time it clears one... very strange.
What exactly is saved with each project? I do hope the layouts of the tabbed windows also? It is annoying to redefine the views
each time I open up a project (the essence of SE is just to be able to measure signals, save the project and two hours later be able to
just open the project again and measuring immediately or am I wrong? It is a loss of time if I have to "makeup" the views again
just by opening the same project again!)
Kind regards,
PBRM
09-05-2007 03:28 AM
O, indeed, in the previous post I speak of DataViews and subviews but off course I mean a dataview divided
in for example 3 graphs and each graph with its own signal... so when reloading a project all there is left in some dataviews is
one graph and even that graph has "lost" its connection with its signal, so basically I'm left with an empty graph,
that is what I mean.
09-05-2007 02:05 PM
09-06-2007 08:43 AM
Hi! I will send you such project but can I do that by email?
I do have the impression that it related to previous SE version projects because if I start a new project from scratch
I don't seem to have this problem so I guess it probably has something to do with the handling of "older" SE projects...
Anyway I will send you a project where the problem occured,...
And if I get the same error again with 2.5 I'll send it immediataly 🙂
greetings!
09-06-2007 10:54 AM
09-07-2007 04:37 AM
Okay, here is the project... I believe one dataview is missing its input, o and I installed SE from version 2.0 onwards,
I did however use it in trial version before upgrading (buying) the full version
greetings.
09-07-2007 10:24 AM
09-07-2007 11:12 AM
