07-24-2007 08:11 AM
07-24-2007 09:06 AM
07-25-2007 01:15 AM
anyone can give me your hands?
07-25-2007 09:42 AM
In the next version of SignalExpress and NI-DAQ, you will be able to plot N Sample and Continuous counter measurements to a graph. The data will be plotted vs. "sample number", not vs. time because in counter measurements, the signal is determining the sample period. For example, if your signal is varying between 1 kHz and 5 kHz, your sample period would vary between 1 ms and 200 us.
In your current version of SignalExpress and NI-DAQ, counter data can only be viewed in a table.
Sensei
07-25-2007 10:59 AM
07-25-2007 01:22 PM
If your calculated Mean is a double it should display as a chart (X Axis will be iteration) and it should be loggable.
07-26-2007 04:31 AM
Dear all, i try to set using 2 counter to measure single point frequency...but why the program SE warm me that the " Sample period too short" , How can i solve this problems??
07-26-2007 09:29 AM
07-26-2007 10:04 AM
07-26-2007 11:18 PM
The sample period is the time between calls to the DAQmx Acquire step. It is a bug that you get the error. Installing the August 2007 Driver CD will fix it.
Graphing the N sample or continuous mode output of the DAQmx step has been added to SignalExpress 2.5 which is also included in the August 2007 Driver CD.
SignalExpress does not currently support timed single point output from a User VI.
