I'm using an external power supply. I don't believe I need the custom voltage with excitation step - but you can correct me if I'm wrong. The next problem I'm seeing is this: I have 4 9234 modules with 12 channels of accelerometers, and 1 9215 with 4 channels of displacement sensors. I'm triggering off of one of the accelerometers, but I when I save the data, the accels and the displacement data times are offset and they don't seem to be writing from the same relative time. I.E. I hit the accelerometer and trigger the start of recording then I pull the string on the disp sensor. When I look at the saved data, I get the proper accel data but I either get the return slope of the disp sensor or I miss it all together. I'm taking 100k samples at 50kHz, for a total of two seconds. I think the time of the displacement sensors have to be off. SE will not let me sub-group across voltage/accel input channels, so I don't see a way around this. Any help would be great.
