05-24-2012 07:55 AM
When I try using the DAQmx Generate Analog Output step on its own in Signal express the triggering type drop-down menu is grayed out. How can I change it so I can specify an analog edge trigger? Do I need to insert an Acquire step before this?
05-29-2012 05:44 PM
Hi Luke,
I have some questions about your application:
What hardware are you using to output the analog signal?
How are you generating the signal to be output? Do you have a Create Analog Signal task first, or are you using some other means?
What kind of signal are you trying to output?
What is producing the analog edge trigger, and how are you going to read it in?
05-31-2012 03:07 PM
06-01-2012 01:34 PM
I have been informed that the DAQ 6008 is not capable of using an analog edge trigger, is this true?
That is correct. The NI USB-6008 cannot use an analog trigger. It is only able to use a digital trigger.
