I am looking for a pxi card to generate 3 channels analog outputs. The idea is to adjust a delay between each of the output. A view of the signal needed is provided in the attached figure. I know that this can be done by using 3 pxi card such as pxi 5402 but this is an expensive way to do it. May be pxi 6711 can be sufficient. For information, the sine waveform has typically a frequency of 1 kHz and the duration of the sequence is approximately 10 s. Does 6711 allow loop sequence to repeat a pattern over an infinite time ? Is it possible to produce three different waveforms on each output channels (i.e., a sine on channel 0, asawtooth on channel 1 and a suqare on channel 2 ???
Could you please provide me some advice on the best card for this purpose.
