05-14-2008 09:27 AM
05-15-2008 10:27 AM
05-15-2008 11:02 AM
Hi Matthieu,
Thanks for answering,
What do you mean by "convert neatly this picture"?
The fact is I tried to open the image i have generated, and it seems to work well when opened with 16 bits depth resolution ... but I am not sure at all the generation part of the VI is able to handle a 10 bits depth monochrome signal ... (video library???)
I join an exemple of a 10 bits resolution image and the VI that is able to open the image (which is exactly the same as what is done in the previous VI I sent), That means that for me the image is properly interpreted by LabVIEW ...
Sébastien DURAND
05-20-2008 02:07 AM
Nobody can help?
Sebastien
11-11-2009 02:10 PM
Hi Sebastien,
Sorry I can't help, but what is this 'Video Library'? Is this from the VideoMASTER software tools, or something else? I'm looking to generate composite video using a 5421 but not sure what tools exist to do this....any idea?
Todd
11-13-2009 03:30 AM
The VideoMASTER generator software can be downloaded from:
http://joule.ni.com/nidu/cds/view/p/id/1211/lang/en
Christian Koefoed
PSE VideoMASTER and AudioMASTER
11-13-2009 01:14 PM
Thanks, I downloaded it an will test it out with a loaner PCI-5421 next week.
Do you know if it works with a PCI-5421? NI's site doesn't offer the video generation version of VideoMASTER with a PCI-5421, only with a PXI-5421.
Todd
11-14-2009 09:18 AM
Hello Todd,
Yes the VideoMASTER Generator software will work with the PCI-5421, even though on the website it is listed only under the PXI-5421. You will need to request an evaluation license from activate@microlex.dk which goes directly to the team that will issue you a temporary license (30 days). Please include the serial number of the PCI-5421 in your email to activate@microlex.dk so they can issue the temporary license.
Finally if you are interested in purchasing the software, simply contact your local NI sales contact and request part number 780933-01 (VideoMASTER Generator SW only) be added to your purchase of your PCI-5421.
Let us know if you need any help as you get started with your evaluation, we will be happy to get you up and going.
Cheers,
Michael Schneider
