07-03-2010 05:39 PM
Yes, I have taken a two-day labview workshop from NI. The reason I am baffaled because I dont know anything about the instrument. And the connectivity between the instument and the labview, could not have been tested.
Thank you for your help.
07-14-2010 03:36 PM
Pratik,
If you are using LV 8 or higher this link will show you how NI provides for quick driver generation, which among other things auto-generates the code!
http://www.ni.com/swf/presentation/us/labview/projinstdrv/default.htm
Good luck!
07-15-2010 03:09 PM
Pratik,
I may have found some more driver helps for you in the form of possibly related 4142 drivers. The NI site has HP 4155/4156 drivers. Since the 4155/4156 and the 4142 are multi channel instruments, the 4155/4156 drivers may be a good point to start from for 4142 drivers. Also, probably best when looking for drivers to search for the model # under the mfg only. This should allow the best chance of finding all drivers that are available. I found the 4155/4156 drivers under Analyzer, but not Power Supply. I guess I was applying the IVI class names in this case and almost missed these drivers.
07-15-2010 04:07 PM
Thank you for the link and suggestion. It was helpful.
I am trying to use gpib-visa.VI gpib.vi examples and I am able to communicate using them.
10-14-2010 07:46 PM
hi pratik,
can you tell me what you did to communicate with 4142b via gpib?
10-18-2012 02:21 AM
Hello
I need help with hp4142b too. can you tell me how can I comunicate with hp4142b? thank you
04-25-2013 11:51 AM
Hello everyone,
I would like to know if anybody has developed the driver for 4142b since then?
Thank you.
