Hi Kirsch,
Just for clarification, the NIFGEN_ATTR_POST_AMPLIFIER_ATTENUATION and NIFGEN_ATTR_PRE_AMPLIFIER_ATTENUATION settings for the pre/post Amp attenuator blocks in the output path are different for different amplitude/gain settings....correct? Meaning if I select 5.5V or 4.3V the driver would write different values for these settings? That's the way I'm interpretting it, you just mentioned that they can be used during calibration so I wasn't sure if that was the only time they where changed.
I'm rewriting some tests that used a different scope that had post-output attentuation control. It seems that the attenuators in the 5412 are configured internally by the driver (via the amplitude/gain settings) so changing the value of the amplitude and measuring via an external device in effect tests the 5412 attenuators.
