07-08-2008 02:39 PM
Hi All,
I would appreciate it if somebody can explain to me what’s meant by the ramp technique and how can you use it to plot the frequency response of a filter?
07-09-2008 07:35 AM
Hi Marwan,
I'm not entirely sure what you mean by 'ramp technique', I have a few possible ideas for what it might refer to.
Could you point me to where you read about it? From there I should be able to help you.
07-09-2008 11:37 AM
Marwan,
I've discovered what's called the Ramp Response (and this is what I initially thought you meant by Ramp Technique)
It is similar to creating the impulse response of a system, but you applying a unit ramp instead of an impulse to excite the system.
does this help?
07-09-2008 01:20 PM
SheelaS
The exercise is to determine the cutoff frequency of a low pass filter by using the ramp technique.
Marwan
07-10-2008 04:49 AM
