06-26-2012 03:28 AM
Hi
I try to generate a triggered analog output signal with a PCI-4461 card. First I tried to use the NI DAQmx function "start analog edge" with the analog input channel AI0 as source and the analog output channel AO0 as task. After this gave an error I tried to to use the NI DAQmx function "start digital edge" with PCI0 as source and the analog output channel AO0 as task. This ran but didn't produce any output. Now I'm wondering if I can use the analog or digital trigger of the PCI-4461 at all for triggering output.
Thanks for you support,
Pribislav
Solved! Go to Solution.
08-03-2012 08:50 AM
Hi Pribislav,
do you still have this problem? I did exactly the same configuration (digital edge) and it works well on my system. The PCI-4461 does not support an analog trigger, thats why you get this error.
Matijas
08-09-2012 09:19 AM
Thanks a lot - it works now. Actually I had a problem with the trigger wire.
